ASI BAC4000 help setting QS 138 90H
GianlucaO
Hi, I bought an ASI bac8000 complete with wiring and display some time ago. I mounted everything but there is no response from the accelerator and the red LED was flashing. Now the display and the red LED do not light up anymore. I found the PIN out of the controller and with a multimeter I created this drawing of the electrical diagram provided by the seller. The IGNITION and Display one seems correct to me but the Brake and Throttle one does not seem correct to me. Can you help me to solve it? I hope the controller was not damaged by a wiring error that I did not make.
Hmmm, seems like there is some weird stuff there. There should be a ground going to the throttle. What display did it come with? Strange that there are two 12V lines going to it.
There is a GND ground (PIN 15 of controller) to the display, two 12v PINs (PIN 16 of controller), TTL RX (PIN 13 of controller) and TTL TX (PIN 3 of controller). The problem in my opinion is the wiring to the Throttle connector and Brake connectors.
hi, the problem of my asi bac8000 is on the 5v line (pin 4 and 8), short with gnd. so i will have to have it repaired. what could be broken inside? do you know what is the electronic part or component that manages +5v?
for the short time it worked the display showed a "throttle voltage out of range" error but nothing was connected except the display and it showed a throttle voltage of 0.06v and a vendor set range of min 1v, max 4v
thanks
Hi GianlucaO,
Are you testing for the 5vdc output with your bad wiring connections disconnected? I.E. It looks to me like Bad pin terminations for Both brake and throttle wiring, well ok, all of them... or have you corrected these from what you show in your diagrams?
I'd like to help if I can.
What is your display make and model?
Regards,
T.C.
Hi GianlucaO,
Regards,
T.C.
Yes, disconnected cables. Yes the wiring was poorly produced by the supplier. The display is always produced by him I don't know if it has a brand, at startup it shows the Bull Bike logo of the seller.
Often the last step down component in the circuit is a LM78L 5 vdc regulator IC or similar.
https://www.ti.com/lit/ds/symlink/lm78l.pdf?ts=1745844354444
Did you check for 12 volt present on pin 16?
Looks like Bull Bike uses this model display…
https://e-racing.world/wp-content/uploads/2022/11/750C-display-low-voltage-version.pdf
APT 750c display for ASI controllers
Controller reference:
https://www.acceleratedsystems.com/...r_controllers_spec_sheet_w_pin_out_table2.pdf
I bought an ASI bac4000 because mine died. It was mounted on a Talaria. Do you know what the settings are for the engine I use QS 138 90H?
Help with ASI bac 4000. I connect the battery (72v) and wait to precharger with resistor 250ohm. Arrive at max 25v. Also with direct wire. When i turn ok Key (PIN 9) the tension go to 0v. Can you help me? Thanks
I am the unluckiest person in the world
How about a wiring diagram of your ignition circuit, and power to B+, including contactor if being used.
I charged the battery to the max 83.9v and now it works. Now the problem is to find all the settings for my QS 138 90H engine. Are they available?
Hello everyone. I am trying to set up my QS 138 90H motor with the ASI BAC4000 controller but I don't have the settings. In the Kilowatt app I have to enter these settings but those with the asterisk I don't know what they are or what to choose. Does anyone know how to help me? I would also like to know how to calculate the motor inductance and how to calculate the hall sensor offset angle. I also noticed that when the battery drops below 77v the controller does not turn on. Only with a fully charged battery 84v. What could this depend on? Motor now autotuned in sensorless mode but don't work well.
