Ecyclist
Finally, I will be installing bigger 80 mm motor on my build. I tested two different motors with a new more powerful ESCape controller and now I'm in the process of installing hall sensors in these motors. I made 120 deg. mounting boards out of FR4 and I installed sensors in them. I followed the recommendation for testing sensors before installation and learned that directional magnet is absolutely necessary to be able to do that. The magnet on the left is a good one. The other on the right will not work.
To test hall sensors I just used a 5V cell phone charger and multi-meter. All seven sensors that I ordered looked OK.
I also made hall mounting boards. This way, I will know for sure that hall sensors are placed exactly 120 deg. apart and concentric.
I will temporarily attach the board with zip ties so I can adjust angular location. After that I will use 400 deg. F silicone to fix boards permanently.
