casainho
- Joined
- Feb 14, 2011
- Messages
- 6,045
Follow the wiki instructions to flash the firmware.Eggybert said:You can get the micro controller to start running after flashing?
What do you use for flashing the firmware?
I you already erased the original firmware, then use the Bafang_LCD_850C_firmware-v0.4.0.binEggybert said:I see you released 0.4.0.
Do I use the for bootloader or without?
Follow this process to understand if the firmware is running and if the issue is on the LCD:Eggybert said:You can get the micro controller to start running after flashing?
my lcd syas HJ3218-01FPC-A2 on the flat ribbon cable
casainho said:Follow this process to understand if the firmware is running and if the issue is on the LCD:Eggybert said:You can get the micro controller to start running after flashing?
https://endless-sphere.com/forums/viewtopic.php?f=2&t=97083#p1489403
Can't help more while you don't answer clear to my suggestions.Eggybert said:casainho said:Follow this process to understand if the firmware is running and if the issue is on the LCD:Eggybert said:You can get the micro controller to start running after flashing?
Then it still is strange that when I use st-link to start the MCU the screen works fine. Only mirrored
Eggybert said:Ok tests so far:
When I press short power on the screen goes white.
When I hold the power the screen goes dimmed and off.
I also looks like when the screen is white and when I press + and power I have to hold the power button long twice to shut down (tested multiple times).
I reinstalled the flat cable with no change.
There is no power assist from the motor in any way.
I think the motor is flashed, when I check with STVP the firmware was the same as the bin file.
I checked the wiring. This is how the wiki told me to splice the cable.
LCD - > motor (6 pin version)
Bown -> Green
Orange -> White
Black - Black
Green -> Brown
White -> Orange
There is no brake sensor
No temperature sensor (yet)
And the torque sensor is not calibrated
So, do you see any time the screen working as expected? Do you see anytime the image on screen as expected?Eggybert said:Ok tests so far:
Bown -> Green
Orange -> White
Black - Black
Green -> Brown
White -> Orange
casainho said:So, do you see any time the screen working as expected? Do you see anytime the image on screen as expected?
When the screen is white, is the motor working as expected if you pedal?
Just turn on the 850C, let the screen be all white and try ride. See if you feel you have motor assistance. Try click up and down buttons to see if the assistant power increases/decreases.Eggybert said:casainho said:So, do you see any time the screen working as expected? Do you see anytime the image on screen as expected?
This is the first time I tried to use the openSource firmware so I'm not really sure how the screen should work.
Pressing the buttons seems to do something like it want to go in settings and switch on and off normally but not sure.
The screen never has any image, just plain white.
The motor never worked, but also this is the first time with the new firmware.
I will try to go to the openSource firmware for the LCD5 and check if everything is working as it should.
Ok, that is good.Eggybert said:From this page: https://github.com/OpenSource-EBike-firmware/Color_LCD/releases
Version: Bafang_LCD_850C_firmware-v0.4.0.bin
Aslo tried: Bafang_LCD_850C_firmware-v0.3.0.bin
I already erased the bootloader just before the bootloader version came out.
I don't know.Depp said:Hi. Can I perform this procedure with my display? I have a Bafang HD motor. The display board is a little different. I disassembled the display due to a problem with the DY transistor.
