I am not really sure if there is a language barrier, but I don't think what you're posting matches what I am. :?
I thought worst case a boost converter would cost you about 10% ( as in, they are capable of 90% efficiency? ) And they are much much smaller as a linear
Hmm. You were asking about buck converters, which is what I was answering (not boost). But:
Boost or buck, there are different kinds of converters. SMPS is what most chargers are, and the common controller (plus the motor) make what amounts to an SMPS. How efficient they are depends on what you're converting to and from, and the design itself. They might be *capable* of high efficiency if done right in the right situation, but they aren't all going to give you that. You can test the efficiency of a system by measuring the input power and the output power, and the difference is the inefficiency's power loss as waste heat.
For the same power conversion, the linear converter is likely to be larger and less efficient, and is just a buck converter, as it is usually wasting power resistively to drop the voltage.
Either way I have not seen a combiner that does either buck or boost...they just keep two batteries paralled to a controller while preventing either from backflowing into the other (using diodes or ideal diodes made from FETs).
Some might have an MCU that monitors the batteries to shut one or the other down based on various programmed limits; I haven't seen one that actually "proves" it does this, or has a detailed manual indicating how that works in it. I've seen block diagrams posted for one that claimed this but the diagram didn't make sense even within it's own claims, so I don't think it was actually what it said it was.
If you know of ones that actually do more than just connect two packs in parallel, please post links to them; I'd like to figure out what they are actually doing inside.
Also, a diode is enough to equalize any differences in same rating packs, but it won't let you combine a 36v and 48v battery to drive a 48v motor.
Diodes (as a battery combiner) wont' equalize anything. They only prevent backflow from a higher voltage pack into a lower voltage one.
The latter part is true, in that a 36v battery, by itself can't operate a 48v *controller* (but could certainly drive a 48v motor...it would just run it at 3/4 the speed you would expect at 48v).
For that a boost converter needs to step up the 36v to 48v ( loosing about 10-20% of capacity in excess heat / conversion losses from that 36v battery ). Or well, again, that was my theoretical understanding anyway.
Yes, but the boost converter (including it's cooling and/or heatsinking, casing, etc) is going to be about the same size as the controller or the system charger, if it can support the full power that the controller is able to draw while doing the conversion. Same thing for a buck converter. And that's assuming an SMPS. A linear version is simpler but has more waste heat and ends up being large too.
Don't understand how the boost converter on the 36v circuit would drain the 48v, it wouldn't since it doesn't interact with it at all. The converter should step up the 36v to the level of the 48v SOC ( as measured by the combined discharging unit ), this would only incur losses in the converter itself not in the 48v battery pack? So yes, you won't get the Wh from the 36v battery, but the Wh minus conversion losses, added to the Wh of your 48v battery, or am I wrong?
I am not sure where any of that comes from or is in reference to, if it is in response to my post?
I looked back at my posts and there isn't anyting about a lower voltage pack draining a higher one? (except maybe that this is something you don't want to happen and hence the diodes in the battery combiners?)
I can answer the part above in detail later though. First, just some info on the concept in general:
None of these combiners that I have yet seen are meant to use something as great a voltage difference as a 36v and 48v pack together. They are really intended to just take two similar but non identical packs (like two 48v packs at different states of charge and thus different voltages) and let you use them "at the same time" without switching wires around, or unplugging one and plugging in the other, etc.
They dont' really let you use both at the same time the whole time, though, if they are just diode (or ideal-diode/FET) based. The pack at a lower voltage isn't contributing current, only the higher voltage pack. When the higher voltage pack has been used enough to be the same voltage as the lower voltage pack, then they both flow current based on their internal resistances, down to the point that one pack's BMS turns it's output off and then only the other pack (whichever that happens to be) supplies the whole load.
That behavior isn't caused by the actual diodes, ideal diodes, FETs, or other combiner properties, its' just the nature of voltage sources in a system.
To make a combiner work by actually sourcing power from both batteries at the same time, regardless of their voltages, it would require a DC-DC converter on each one, that each by itself is capable of supplying the full power of the entire system (so when one shuts down because it's battery is empty, the other doesn't blow up or shutdown from the extra load), and can convert voltage from the input across the entire range of voltages of all the packs that could possibly be used with it, to the entire votlage range that might be expected on it's output. The wider the input range, and the wider the output range, the bigger / less efficient the DC-DC is going to be. And you need one for every connectable pack, built into the device. It's not going to be a small device, and it's going to make a lot of heat, and it is going to waste a lot of battery capacity.
If you just have random batteries you have to use to get enough range, such a device could be useful and worth having...but normally you'd be using batteries that are very similar or identical in voltage range to start with, and just ahve slightly different states of charge, so simple diode paralleling devices are sufficient.
