Bafang BBS01 / BBS02 controller factory setting - how to do?
Hello,
I'm looking for the easiest & quickest way to reset the BBS01 / BBS02 controller back to factory setting (original speed and power limits) without using a notebook. Is it possible via button combination or reset button at the display (C 965) to do the reset and override the customer settings?
Regards,
Tom
I am 99 percent sure you can not do this through display. One option may be the unit described here https://endless-sphere.com/forums/viewtopic.php?f=31&t=79986&p=1221911&hilit=+switcheroonie#p1221911 to restore to factory settings with out using a pc.
If the reasoning for switching back to factory settings is from a legal, oh hello officer, point of view, then there is no quick way of doing this.
If on the other hand it is so that you can do it on the road, without lugging a notebook around, then as waynebergman mentions, the Switcheroonie may suit your needs.
