No it should not. Throttles usually work in a range of ~1V-4,2V, so it will require the signal to beGoing back to throtlle- it should run full speed just my shortening pin 1 to GND? There's no reaction in my case![]()
Does that mean that you think much more highly of UART than CAN?Why would you change an inherently simple machine to an unnecessarily complex, less reliable control system if there's no practical benefit in doing so? That's car driver nonsense.
That’s in regards to a motor’s hall sensor which is a digital type, or off and on. Remove the short and verify output as follows…ok I read somewhere that when putting magnet to hall sensor it make 0v on output- so connect output to GND.
As opposed to digital, I guess -- and guess further that most systems & kits, and both CAN and UART, are digital, not analog.No, I prefer the reliability, diagnosability, and serviceability of all-analog system components (outside of the controller's microprocessor anyway). Anything that doesn't help the bike go has no place on my bike.
Can you give an example of an [almost] all analog system?
A throttle’s hall sensor gives a linear output from about .8vdc in the home position, to say 3.6vdc at WOT. (Top voltage is dependent on incoming supply voltage.)
So check ground to signal output for these voltages at the different throttle positions. With a smooth ramp up in the middle.
For a deep dive into throttles, se this thread…
Guide to Hall Sensor Throttle operation, testing, and modification. - Electricbike.com Ebike Forum
I would be cautious of the two different VCC voltages, #2 and #6… I would suspect #6 or ORANGE to be full battery voltage.
Regards,
T.C.
what now?
right I always ommit smth
I appreciate a lot your will to guide me.The first thing I would do would be to disconnect the damaged throttle, after correcting the wiring back to how you had it.
Then check to see if you have the 5vdc voltage yet from the controller. Pin 2 to ground.
Do we have a language issue, and how are your troubleshooting skills with a multi-meter?
Be sure to have battery disconnected when checking resistances, and when connecting or disconnecting parts connected to the controller.
If you have questions or not quite sure what I mean or describe, be sure to ask first.
I will always advise directly on what and where to check, or what to change.
Good luck.
I’m curious, how are making these pin changes anyway?
Can you give an example of an [almost] all analog system? Please forgive my ignance; I must admit I don't understand very well most of what makes an ebike work well or not, nor most of the electronic subjects discussed on this forum.
This is good.On pin 2 there's 4.95v
What make and model of display are you using?but I als cannot power off the system- then it shows error code 30
I’m curious, how are you making these pin/wiring changes anyway?
Do you have a link? Why did you choose a CAN bus model that you can't communicate with?I bought OEM controller
There' are lot's of resistors or other smd's around LCD connector- so maybe it was tosted first...
I was looking for controler on local market for over a year. and I found this one.Do you have a link? Why did you choose a CAN bus model that you can't communicate with?
Have a link? Does it also have gear, speed sensor or light plugs? For an 8fun bike?and I found this one.
Surely the controller’s ground goes to two pins…? Worth a recheck… Harness has both display and throttle connectors right?all connections are 1-1, no shorts.
That will be up to you to decide if you want to crack it open or not. But if it’s stuck on, I would not recommend it being used.It will be difficult to open LCD there are no screws
