sam1am
10 µW
Hello all - I'm hoping to find some assistance in tracking down an error. I am seeing "er 30" which google tells me is a "communications error." Unlike others, I can rarely get the assist or throttle to work at all. Sometimes if I turn on the system, quickly increase the assist a few levels, and wait after the er30 shows up, it will work until I interrupt the pedals and then no more.
I suspect either the battery or the crank sensor to be at fault.
Is it possible the battery could be causing this error? I am using a 48V20Ah Allcell lithium battery. Perhaps damaged BMS?
Apart from that, how can I check the crank sensor to see if it is functioning properly? It was working intermittently prior to getting this message 100% of the time, so maybe it finally failed totally.
