No, but whenever I find any definitive evidence from a trusted source, I will certainly save it.
WoodlandHills said:I fully expect to see a complete redesign in a year or so that addresses the weak spots, like the plastic gear, the chain line offset and others. I would also expect there to be a 2000w heavy duty version for racers and cargo bikers too.
Ditch Doc said:Is everyone planning to leave the amps at 30, or increase them with the programming cable?
MrZo said:I got mine delivered last week but I haven't been able to install it.
The programming cable that Luna sells works fine but setting the current above 30 produces an error.
The motor really looks like it can support more than 1500 watts, Now that I have it with care I even think the nylon gear will hold up.
It really looks like Bafang just wanted to make a reliable 750w mid drive. It even has a 750w stamp on the casing.
dumbass said:MrZo said:I got mine delivered last week but I haven't been able to install it.
Keeping in mind that many or most of the 750 kits are sold in the US. And in most US states the max limit is 750w. Could this be why the cases are being stamped 750w?
WoodlandHills said:I bet I would go faster if I put it on my 27 speed recumbent........ :wink:
Dogboy1200 said:The same cable and software that worked to change settings on the controller with the 02 works with the HD. It came from Luna set for throttle in PAS 0 they way I like but they had Max amps at 25. I tried it like that then bumped it up to 30A (controller won't accept any higher number). I also tried setting throttle mode to speed and lie about the wheel size
Exactlytommie said:Dogboy1200 said:The same cable and software that worked to change settings on the controller with the 02 works with the HD. It came from Luna set for throttle in PAS 0 they way I like but they had Max amps at 25. I tried it like that then bumped it up to 30A (controller won't accept any higher number). I also tried setting throttle mode to speed and lie about the wheel size
So you can programme all the controller settings like the BBS02 except you can`t exceed the 30amps - is that what you`re saying?
Interesting.
