Yes.alfantastic said:BBS02 48v 25A 750w.
This probably isn't a fault at all and may be a characteristic of the system.
Does anybody experience a small click, when turning the pedals forward again, after the pedals have been stationary?
It will do this only when moving, whether PAS assisted or the system is turned off. It clicks only once, well, at least until the pedals are stationary again.
It sounds like the pawls re-engaging, for the pedals to assist with driving the chainring. The whole set-up works flawlessly, so I'm not fussed by this, but was wondering if it is actually a characteristic of the Bafang BBSxx.
speedmd said:These odd little sounds are not faults in general and mainly don't need fixing. Lots of what folks are wanting / expecting out of this system just is not going to happen with the design. If it runs and does not make significantly ugly sounds, it should not be on this thread IMO. Certainly not a good thing, that it makes odd sounds here and there, but I do not believe re-engineering out normal noises is a topic we need to mix in with lights out type issues that are plenty enough in this relatively complex system. A good thread topic would be "BBSxx early warning sounds", "Sick sounding BBSxx", or "BBSxx not yet broken sounds" for the not yet broken systems. From the looks of it, that thread will be significantly large enough on its own.
This wonderful forum is to loosely moderated for that to happen. Now before anyone gets frustrated by that, I appreciate that attitude most of the time. I also understand that moderators give a LOT of time to this place. Perhaps a new thread or two and a Bafang moderator? OR we work together and create a FAQ for moderator approval? It sure would be nice to find information without spending and hour to flush something out.speedmd said:The BBSxx is a complex system by itself and even more complex when adding all the bike / frame fit and assembly issues. Mechanically alone the system is much more complex than most ebike setups and with it's wide spread use, I see a single topic thread for faults growing out of proportion to real usefulness. This is before we get into the nitty programing, controller, display and other electrical input/ troubleshooting issues. Not sure how best to organize the topics here. Maybe the moderators have some better insight.
Tamaz said:So i just got this problem on my kit, but its not only when moving the pedals. The same symptom apears when riding along by throttle if there is a lot of resistance. I suspect its the one-way bearing that is inside the plastic gear that slips. I have ordered a new one to replace it.
https://www.youtube.com/watch?v=4X3RCYICcSQ
BBS02 48V 750W
1405141880
Teh Stork said:Symptom: Creaking / noise coming from crank/motor area when pedaling. Only creaking when putting weight on left pedal.
Throttle only: no noise.
Noise is synchronous with pedaling. Chainwheel/chain not at fault.
Freewheels as it should
BBS02 750W @500W
Milage: 400 km - with hard use in urban areas.
Tried tightening the screw holding the "crank-innards-assembly", did not alleviate the issue.
micopl said:Teh Stork said:Symptom: Creaking / noise coming from crank/motor area when pedaling. Only creaking when putting weight on left pedal.
BBS02 750W @500W
The exact same thing happened to my motor yesterday ( bbs01 350W, 1100 km ).
My first guess was something was wrong with the left pedal itself but now i am not sure, will investigate further.
tahustvedt said:micopl said:Teh Stork said:Symptom: Creaking / noise coming from crank/motor area when pedaling. Only creaking when putting weight on left pedal.
BBS02 750W @500W
Retighten the crank arm to 35 N (which is more than you can do with a little allen wrench). Retighten the large bottom bracket nuts. Check the nut inside the bottom bracket housing.
puregsr said:Symptom:
Continuous squealing sound when pedaling under human power, goes away whenever motor engages both throttle and PAS.
Strange that it happens after it warms up or after riding for a while, quiet after resting for a few hours.
Anybody with the same probelm?
I have repaired the power connectors and the kit works now. Thank you very much!mushymelon said:First try disconnecting the ebrakes and throttle and try again.
Could you elaborate on how these test were performed (54.4v when it's on and 51.7v when it's off)
Your getting a good spark so thats a good thing but those power connectors are very poor. I highly recommend changing them.
Check the small pins in the main harness with a light make sure none are folded over.
I don't see any errors on the display they all show zero for a sec then display remaining battery.
Run through the basics first and go from there.
-Reduce wiring to only display and battery
-check and recheck power connections
KnNashua said:Error code 12 - Bafang BBS2 500W with C961 display
Upon startup this week 80% of time over 20 rides, I get error code 12 and bafang non-functioning. Shutting off and restarting consistently clears code and then runs smooth for miles.
From C961 Manual error code 12 is "current sensor abnormality", which I believe is correct for code (old BBS manual I have says code 12 is "Temperature inside of battery is
un-normal") (Random red herring or possible important detail, at 600 miles it started randomly adding resistance when not assisting (if you leave on come to stop and move bike backward/moving peddles it feals like brakes slightly on, no code shown, shutting off and restarting behaved normally immediatly, then this stopped for 50 miles and happened twice this week.)
Two questions:
What should/can I test and how. (ie voltage or current and when)
Also other than the hassle, should I be concerned about fixing instead of using to avoid damage?
Any input? THANKS
