Just out of curiosity this is what Google AI came up with:
27,000 eRPM (electrical revolutions per minute) for a geared hub motor is a high, typical operating speed, usually translating to a very fast physical wheel RPM (often 1,000–1,500+ RPM). It indicates high power, with the motor likely spinning fast to achieve top speeds often exceeding 30–40 mph, especially on 1000W-3000W+ systems.
Understanding 27,000 eRPM:
- eRPM vs. RPM: The geared hub motor's internal motor spins much faster than the hub shell (wheel). The 27,000 eRPM is the speed of the magnetic field switching, not the wheel's rotation speed.
- Calculation: The formula is eRPM=RPM (physical) × Pole Pairs × Gear Ratio. A high eRPM like 27,000 is common in smaller, fast-spinning, high-pole-count brushless motors found in e-bikes.
- Performance: A geared motor spinning this fast suggests high-voltage, high-performance setups (e.g., 52V-72V batteries).
- Limits: If the motor is small, 27,000 eRPM might approach the limit of its internal nylon planetary gears, potentially causing faster wear.
