ericmann2000
100 µW
- Joined
- Jun 5, 2009
- Messages
- 7
Hello everyone
i'm new here. I got this bike from a shop for free without batteries (the original pack was nimh 24v 8ah). Here are the pics
http://img200.imageshack.us/gal.php?g=controllerwiring.png
the motor is labelled bafang swx01 24v 250w. the byke has PAS and no throttle.
i got some questions
1) as you can see on the label there's written 48-36-24 Do you think they are voltages i could use ? I'd like to use 36V . can i fry something ?
2)the controller has black and red wires that are disconnected . Do you know what they are for ? could it be for throttle ?
3) is the white-white a speed limiter ?
4) the controller has a jumper . do you know what is it for ? could it be for lvc voltage ?
5) watching tha label : if 15A is max current output what's 7A (could it be current with limiter) ? 20.5V is the cut-off? what's 1.2-4.4V (could it be throttle range) ?
the only info from a search on the forum (from here viewtopic.php?f=28&t=4625&p=72137&hilit=swx01#p72137 )are :
- 24V controller version has cutoff at 17V, it can handle up to 50V
-the controllers only differ in the cut-off-voltage,
thanks
cristian from italy
thanks
cristian from italy
