Freddyflatfoot
I have just started having an issue with my throttle LEDs, and wondering if I should be concerned about a more serious problem, or whether I just have a faulty LED.
My system is a stock bafang, stock 36v controller, and twist thottle with 3 LEDs, and a 36v/10AHr Ping pack.
Here is what is happening, my bike is fully charged and I turn it on. Good, all 3 LEDs are lit.
I then apply the throttle and the green LED goes out, so far, so good, its under load anyway. However, when I back off the throttle, the green LED stays unlit. My Watts Up says I have plenty of voltage, around 40 volts. Even if the bike sits for a while, (like at work during my 8 Hr shift), I switch her on and still no green LED!
I'm a bit baffled as to what is happening, as it has never done this before. As far as I can tell, peformance is not affected.
Is this indicating a potentially more serious problem, or do I just have a failing LED?
Any thoughts on what I should test/try?
