ChanW
New here
- Joined
- Aug 26, 2021
- Messages
- 17
Hi ES people,
I've set up my new Baserunner (upgraded from the Grinfineon 35A controller).
I have a few questions, and one slight rough spot.
My system:
Grin All-Axle (Fast wind) on a 20" wheel (recumbent)
Baserunner V4 (70A max phase current)
52V 40A 14.5Ah battery
Cycle Analyst V3
24Pole PAS
The rough spot is that when the bike is at a standstill, or maybe rolling backwards a hair, hitting the throttle will make the motor jerk (sometimes just once hard, sometimes repeatedly jerking more softly). I don't recall this behavior at all with the Grinfineon.
If it's a hard jerk, it feels like it then cuts out momentarily too. In the Phaserunner Suite Dashboard this hard jerk will pop up a momentary Fault that says something along the lines of "Hall Error" (it disappears a bit too fast to read)
This behavior doesn't happen if I'm moving forward at all before hitting the throttle.
I've set the system up with the Grin-recommended settings for both the Phaserunner Suite, and the Cycle Analyst adjustments (throttle ramp-up etc), and I've used the Grin defaults for the All-Axle in the Phaserunner Suite.
In an attempt to find a solution, I've now run the Autotune routine in the Suite, and it gave me some different motor settings than those provided by the Grin 'All-Axle default settings' download.
However, the Autotune didn't fix the jerk-at-standstill problem.
I also played with the Ramp-up multiplier for throttle output in Cycle Analyst, with no joy.
The problem seems to be a lack of power to start from a standstill.
Any suggestions are greatly appreciated.
I've attached the before and after Autotune screenshots below.
The 11.71 rpm/V was the default downloaded from Grin
The 11.93 rpm/V was after Autotune
(Is going with the Autotune recommendations better than the defaults from Grin?)
Thanks for any help.
-- ChanW
My system:
Cycle Analyst V3
24Pole PAS
-- ChanW
