I'm running a Phaserunner V6 L10 with a Superharness and Grin SW102 display. I bought a 3-pin hydraulic brake setup hoping it would output an analog signal but it appears to just go Lo/Hi on the voltage output. I also have a thumb throttle and an ERider T17 torque-sensing bottom bracket. Do I need to just source a true analog brake setup?
if you are using the ts i think that you then only have one analog input on the pr available, used for the throttle. so if you want an independent analog control for the brake you'll also need a systme like i used on my sb cruiser to switch between the throttle and the brake control, that also tells the pr yo'ure braking.
if the superharness has it's own analog brake input then you don't need that, but if it doesn't then you do. i've never used one so i don't know it's details.
tjhat said, there are many ways to make an analog brake control. cable-operated throttles, magnet on lever and hall sensor on body or an extneded bit of something, modifying an hwbs hidden wire brake sensor taking the digintal sensor out and putting analog one inside, using a regular th rottle on hte analog brake input, using digital brake lever swithc to trigger braking and control via your throttle, etc.
so, firs tdecide how you mehcanically wnat to interact with the brake control. what physical kind of control do you want, and how do you want it to do what it does for you, how do you want the braking action to happen?
with that, a system can be thought of to do that job, though it may require significant diy on your part to maek that happen.
I don't really mind it being digital as long as it makes some sense but, as you mentioned, it feels like it aggressively increases braking force at low speed which I'd love to be able to program out or figure out how to operate differently so that it doesn't do that or does it less.
If you don't have control over the braking force, and just use on/off control, then you're stuck with whatever the controller is designed / setup to do.
If there's a setting for the braking force (current) curve, I've yet to find it. :/ There are "advanced" settings but Grin provides no data on them. In one of my PR threads around here, there is at least a list of them, and some data someone else linked to, if you want to explore those. (I have not yet done so because everty8ing "works" and i don't want tos crew up anyting since it's my daily ride and only transportation until i someday get to build the new trike)
