mnplus1556 said:
anyone know about how many miles i should expect? it's a 24v 30amp controller. i will not be pedaling unless batteries die. it will top out at 23 mph and probably cruise at 22ish. i will set it up like this:
(parallel:18ah, 12ah, 12ah) in series with (parallel:18ah, 12ah, 12ah)
about how many watts need to be drawn to go 23 mph?
and how many amps per battery and per parallel circuit will be being drawn?
thanks everyone!!
Well the mileage you will get depends on SO many factors it’s impossible to say but you can do some basic calculations based on the controller and motor and on the battery pack. This is just my best guess and I’m probably not going to be on the money but here goes.
24v x42ah = 1008watts of power. Now this is only in theory because Lead acid batteries do not like being discharged at high currents like we use in ebikes so they just can’t put out that much. In reality you’re looking at getting 50% capacity out of them if you deep cycle them (not good for battery life) so say that you have maximum of 500watts of useable power in your battery pack.
If your motor is a 500w (not sure as you never mentioned your motor but just as a guide) continuous motor running on 24v then you are going to be drawing around 20.8 amps from the pack at 100% throttle.
your controller is a 30amp max controller so should be capable of putting out 20.8amps continuous to run motor at 500w. (Controllers usually only put out 75-80% of their rated amperage continuously)
So at 100% throttle you would be able to run for about 1 hour on flat ground. Now you have to find out what’s your max speed at 100% throttle (if thats 23mph then thats your rough answer). Once you know that then you know what your rough range will be.
Obviously this does not take into account terrain, temperature, wind speed or peddle assistance and all of these do have a marked effect on distance so hopefully now you will see that finding out how far your pack will take you is almost impossible to find out without getting on it and riding until it’s out of juice.
as for how many amps per battery and per circuit are drawn, i could well be wrong her but I’m under the impression that as you have 2 12v 42ah packs they will each split the load roughly 50/50 so at 20.8 amps each pack would be supplying around 10.4 amps. now as you have 3 batteries in that pack and one is 50% larger than the rest at 18ah that battery should supply 50% more current then the other 2 so your 12ah batteries should be supplying about 3amps each at the motors 500w rated wattage and the 18ah battery should supply about 4.5 amps. If you’re starting off from a dead start or going up a big hill then your controller is going to push as many amps as it can do into the motor so in these situations you can add probably 50% more to the amp draws on your batteries.
I hope this helps and as i say, this is only my understanding of how it works so if I’m wrong then someone, please put both me and mnplus1556 on the right track
