Keen observers will notice I've changed the title of this thread to incorporate my trials and tribulations on my journey towards building the ultimate power lead solution. Ideally (to me), the power lead should easily connect to the bike, disconnect in a crash relatively easily and be just about invisible during all other aspects of riding.
So far, I'm very happy with the magnetic Anderson connector housing I posted pics of earlier in this thread. This connector covers the first two requirements. The third requirement, however, is where the challenge really lies. I've got a few ideas about how to accomplish this, this next post will cover attempt number one.
Here's all the parts of the mechanism laid out. Essentially, there is a pulley on the end of a bungee that feeds/retracts the power cord into/out of a PVC tube. In its resting state, the bungee holds the pulley with the power cord at the top of the PVC tube. As the rider moves around on the seat, stands up, what-have-you, the bungee is put under tension and the power lead is doled out.
A closer look at the power lead carrier pulley. There are two sealed bearings inside the printed pulley and it rolls very smooth.
There were multiple iterations of this pulley carrier:
There is another pulley at the top of the tube. This is where the bungee cord runs.
All put together.
This the best pic I could get before I just gave up on it, but it shows the power lead pulley carrier in the fully extended position at the bottom of the tube. If you look closely, you can see have the pulley actually guides itself along the inside run of the power lead and keeps itself aligned. This happened by accident, but it works beautifully.
This is the old single battery tube test pack, looks more and more like Hyena's ghost-buster backpack
Inside a regular back pack and you don't even know it's there.
But there is a problem with this design that I have not been able to solve (as of yet). The power lead extends/retracts smoothly in all rider positions EXCEPT, and this is a big one with the kind of riding I like to do, when you need to get your @ss behind the seat. Like in steep downhill descents or bunny-hopping obstacles. In this scenario, the power lead drags along the riders rear-end and this friction causes the lead to disconnect about 50% of the time. You can also feel the added resistance when it drags across your clothes even when it doesn't disconnect in this position.
So, back to the drawing board. I've got two other solutions in mind, but feel free to add your $0.02.
