I am working on a go-kart, mainly for a pre-teen boy, and need to figure out what batteries to use. The motor is a Mars 10kW BLDC and have a Kelly KDL series (300A) controller. I want to run the system at 48V. Top speed isn't critical, though with the current gearing, wheels, etc, calculations show top speed would be about 35-38mph. I will dial this down in the controller for main driver, but may turn it up for others. Anyway, I need to figure out what batteries to use in order to figure out how big the battery trays I need to add to the sides will be. I am leaning towards initially scrounging (or buying new) AGMs or similar but not really sure which ones to look for. I want a reasonable amount of run time, say 30-60 min, but obviously don't want to spend a ridiculous sum or add more weight than absolutely necessary (I realize it will be heavy in any case). Any ideas on what I should look for that is reasonable in price and performance for this application?
Assuming the kart is fun and gets used I will probably build a Lithium Phosphate pack of some sort in the future - unless some amazing pack comes available to buy in the next year or so at a reasonable price.
Thanks for any suggestions.
