I'm having some issues with a 36v 12ah battery I purchased around 3 months ago. The issue is the battery discharge cuttoff voltage is occuring earlier than expected, most commonly around 34v when its advertised to be as low as 27.5v (30v seem more reasonable though). The bike low power is set at 31v but the power completely switches off so I guess it the BCU thats shutting things off.
I went with the cheaper option and purchased a battery made up with generic chinese cells but even so, I'm losing around 1/3 of the rated battery capacity due to power shuttoff. Should this be expected for these type of cells in a relatively new battery? Its much worse than I expected.
I tried to balance the cells by leaving it charging overnight a few times using the charger that came with the battery. This normally charges the battery to 41.8v which once unplugged drops to 41.5v after around 5 minutes with no use. Once peddling, battery sag isn't too excessive, maybe around 1v using medium power settings. Should I try to balance it more or for longer?
Also, how can I trouble shoot this? Could one of the cells be bad or is it just a poor quality battery that won't balance? Could it even be a poor connection in the wiring somewhere? I have access to a multimeter so I'd like to try to diagnose it myself before attempting to use the warranty due to high shipping costs from where I live.
I'm running a bafang BB01B 350w which is down tuned to 250w which I'm using for commuting so I don't think I'm putting unreasonable stress on the battery.
