battery gauge wire
hi could anyone with the knowledge recommend the correct gauge wire for controller and wiring batterys ? looking at 72v 1500 watt 45amp controller whats suitable please ? 10 gauge car audio wire? will that take the volts amps ?regards to all ebikers
Here are a couple of links for battery gauge thickness versus current carrying capacity...
http://www.powerstream.com/Wire_Size.htm
http://en.wikipedia.org/wiki/American_wire_gauge
Or as YPedal says, use 12 AWG unless you have a long run, then use 10 AWG. :D
Ambrose
Be VERY wary in your choice of wire... particularly car audio wire. That industry is full of frauds and mis-speced specs. My testing of car audio wiring showed many "100% pure oxygen free copper" wires (even from big names) was not. Some was plated aluminum at 1.6 times the resistance of copper. Others were mystery metal with over 3 times the resistance of copper.
Some 4 gauge wire was maybe 10 gauge, surrounded by lots of (cheap) insulation. You might think that you bought 4 gauge, but you got 8 or 10 gauge in disguise. In the heavy gauge (0 - 8 gauge) material, the Scosche EFX Flux cables and Excelene welder cables tested very well.
Ypedal said:
The best stuff i've use so far is the hobbyking.com silicone stuff ( supper soft, and crimps well.. )
If you are curious about its actual quality/resistance/material/etc send me a foot or two and I'll test it on my HP3458A 8.5 digit meter with the Kelvin connections... I can resolve down to micro ohms.
Did that test ever get run? :)
If you really need large cable at a good price, welding cable can be had cheap at most welding supply shops. I got 20 ft of 2 gauge for $40 IIRC. They had everything from 8 AWG to 0 AWG.
Nathan
