vjpcat
100 µW
hi everyone - i'm new here and don't know a whole lot about ebikes, but i've got a serious problem with my set-up and don't know what to do or if the system is fried now or what.
here's a little background on my bike:
a friend gave me her bike which had an aotema front hub installed powered by three 12v batteries (i am unsure if they are in series or parallel or what kind of batteries they are - they are newer than the bike's motor system as my friend had replaced them in the last couple of years)- i believe she said she purchased it from evergreen. it is an older model that she purchased several years ago. she gave it to me in august last year. it was not completely working - the throttle lit up, but no power was going to the hub. i found a document online which had the troubleshooting procedure and all seemed ok, but the connectors to the hub broke off, so they might have been weak. i replaced the connectors (anderson? look like trailer connector) and got the bike working ok.
since then i had used it a few times and then decided to move the system to another bike, which i did successfully. i haven't really rode it more than just down the street and back while testing it and working on the bike. the last time i rode it, i noticed the battery warning light come on on the throttle, so i plugged it into the charger the same as i always have in the past, only this time i noticed there was no spark or pop when i connected it. i let it charge until the charger light turned green and went to unplug the battery from the charger. it seemed tight and like it did not want to come out, but i kept on pulling and was able to separate it, but there was a lot of sparks and possibly a flame for a moment. very scary. i just tried to move the plug connected to the battery with a wood handled rubber spatula and again, more sparks and a flame. it appears to be welding itself onto the metal bike rack which supports the battery.
i am afraid i t may have fried the whole system, but i am scared to touch anything now as the cable coming from the battery is still live. anybody have any thoughts or suggestions. i am at a complete loss. thanks much for your help!
jaime
RCA style female connector
you can see where it arced onto the bike rack and burned it
battery charger and male RCA style plug that connects to battery for charging
controller is attached to bike just below seat
battery bag on metal bike rack
jaime
