Jeremy Harris
Thought this might interest one or two when choosing battery types.
I've been looking at a 36V 20Ah battery pack for a low peak current application and decided it was time to quickly check the current price/weight/capacity situation for readily available (read "eBay".........) battery packs before just buying a Ping. The results were interesting.
Price: The cheapest by far is to go with some relatively low maximum continuous rate (10C) LiPo cells (not a problem in this application, as they will only be discharged at around 0.5C peak, around 0.15 to 0.2C average). Next was NiMh, with the Ping LiFePO4 being by far the most expensive.
Weight: The LiPo cells are the lightest, with the Ping LiFePO4 quite a bit heavier. As expected, the NiMH cells are heavier than LiFePO4, but not by much.
Here's the actual results (sorry for the UK figures, I guess you guys in the US can multiply the price by 1.6 or so to get the $ figure and multiply the weight by 2.204 to get lbs):
£ per Wh:
LiPo £0.25
NiMH £0.48
LiFePO4 £0.72
Wh per kg:
LiPo 176.2
NiMH 66.6
LiFePO4 102.9
Given that there is some evidence that LiPo can be both reliable and safe when used carefully, I have to say the current best choice looks to be LiPo (if you're prepared to mitigate the fire risk). The fact that a 36V, 20Ah LiPo pack only weighs 4.2kg is a substantial advantage for my electric boat project, as I want to have an easily removable battery pack. If the specification for the cheap LiPos is accurate, then this pack would be good for around 200 amps. Pretty impressive for the price.
Jeremy
£ per Wh:
LiPo £0.25
NiMH £0.48
LiFePO4 £0.72
Wh per kg:
LiPo 176.2
NiMH 66.6
LiFePO4 102.9
Jeremy
