Johnny A
🧲 New user
I had the same issue with the temp sensors, the motor sensor seems to be the culprit.I flashed this fw yesterday on my 52v bbshd.
On my first run the bike went into thermal slowdown, once when climbing a steep off-road dirt hill, but this is one I done regularly with my original fw with no temperature errors. The bike again ramped power down on a high speed road run, flat road at about 30mph after 4 minutes.
I since went into the configuration editor tool and disabled the temp sensors and bike runs fine again with no errors.
The temp sensors settings in the fw are definitely set to low.
Also the gear sensor doesn't work anymore, but I was probably expecting that to happen.
However the bike does feel a lot more responsive overall.
Not sure if it's worth the hassle of flashing this fw to be honest.
Depends what you want from it.
The Devs are aware of this issue and I believe are working on fixing it
