Can you install 30A then in stead of the 28A limit?Official 1.3.0 released. Flashed and so far working.
I think so, yes. I only use 20A max with my 25000+km BBS02B.Can you install 30A then in stead of the 28A limit?
Max Current
Maximum current to draw from the battery, max 33A (limited by secondary NEC microcontroller, cannot be increased further).
WARNING: Maximum current can be set as high as 33A for BBS02 but I seriously advice against that as there is a good chance you will break your motor! I fault has been observed on BBS02 when setting higher current, possible some form of hard overcurrent protection. If this is triggered power will be cut for a few seconds, lower you maximum current to avoid.
Configuration Tool
Open source firmware for multiple electric bike motor controllers. - danielnilsson9/bbs-fwgithub.com
When flashing the firmware, yes. But you can change parameters in the config tool without power cycling the controller I think.Is it necessary to turn off the motor power when uploading the software?
When I change the temperature reading from only one sensor, do not disconnect the power and everything was ok.Ale możesz zmienić parametry w narzędziu konfiguracyjnym bez wyłączania zasilania kontrolera, jak sądzę.
Same thing as in stock bafang firmware - motor PAS power decreases when you pedal too fast / you get more power when you pedal too slow.What does Keep Current and Keep Current Cadence mean in the new firmware? I don't speak English and I use Google Translate.
Now working correctly in v1.3.0, thanks for sorting that Daniel.@Daniel, I've just rechecked this and the power up throttle guard feature definitely seems to be non functional in the BBS02 fw.
As stated, if I power up with active throttle applied the bike immediately takes off.
So 33A is to much for the motor to handle?Yesterday, a few hours before the 1.3 update, I decided to flash this firmware for my BBSHD 52V.I changed the max current to 33A and feel the difference compared to the previous 28A. My clamp meter when going uphill showed 33,8A.
Unfortunately, after ~1 km of driving at full power, the engine began to stop and weaken, and after a while Error 11 popped up. In walikng mode, the display showed a temperature of 74°C. I saw that there was already such a case and it helped to select the temperature reading only from the controller sensor. It seems that it also worked for me, after driving ~ 10 km with full power, the temperature of the controller is 60°C.
Is it necessary to turn off the motor power when uploading the software? I have a battery built into a fiberglass box and I have to open it to turn off the power to the motor.
Thank you for your work on the software and best regards from Poland.
At the moment it seems not possible for BBS02B. If you install this fw there's no easy rollback -for the moment- cause the flash tool doesn't have read/dump functionalityHello everyone thank you for the excellent workhow to make a backup of my original firmware BBS02B before flashing the new one I would like to be able to go back if there is any problem
Any video also published to guide the most novice ?
Thx
Thank you but it would be a firmware for a 52v version and I have a 48V version.There is no way to backup original firmware but there is some firmware available if you google CRR1094824E010015.3_170815.hex
I did not test it personally.
Before flashing the controller is Off, you turn on/connect the battery after clicking Download in the software... Maybe like it can only download the firmware during the "boot".according to install manual:
4.connect your controller to your computer using the programming cable.
is the controller supposed to be ON during this?
i assume so, just trying to confirm
I really want to test it on my bbs02b but the fact of not being able to return to the stock firmware slows me down in my decision.Before flashing the controller is Off, you turn on/connect the battery after clicking Download in the software... Maybe like it can only download the firmware during the "boot".
This isn't needed when using the Config tool, the configuration tool works when controller is powered on.
Cruise control works, but I don't use it much. It engages I think when I both pedal and use throttle. Back pedaling, brakes or throttle will cancel it. Of course this only works if you configured the assist type as Cruise. You can download the firmware and look at the config tool without actually flashing firmware.
I was in the same boat but I finished my new 12S li-ion battery and really needed that lower voltage cutoff to use its capacity. Then the 1.3.0 came out so I risked it and now I don't really want to go backI really want to test it on my bbs02b but the fact of not being able to return to the stock firmware slows me down in my decision.
I have the impression that it would also remove the on/off accelerator problem if someone can confirm it?
Thank
NO. I think not. It is probably a sensor error inside the engine. Theoretically, the controller should heat up faster because it has lower thermal inertia than a massive statorSo 33A is to much for the motor to handle?
What firmware have you flashed on your motor?
Well, I took the step so many settings possibleI was in the same boat but I finished my new 12S li-ion battery and really needed that lower voltage cutoff to use its capacity. Then the 1.3.0 came out so I risked it and now I don't really want to go back18 PAS levels, working throttle + PAS with no hardware mods, controller temperature on LCD, configurable keep current cadence and road speed limited PAS levels are really nice.
