BBS02 - How do I make the ride more smooth? (re: too much power?)
sofakng
🧲 New user
PA, USA
I’ve just installed a BBS02 with a 52V battery and I used a programming cable to set the Low Voltage Cutoff to 43V (I couldn’t set 44V) and the Current Limit to 20A.
However, I think I might need to adjust the PAS levels because even PAS 1 is too powerful. Can anybody give me some suggestions?
Also, is there anything to make it smoother when I am pedaling slowly so the motor doesn’t engage, stop, and then engage again over and over?
If you have the programming cable you should also be able to program the different assist levels to your liking regarding amps and speed percentages.
Hmmm... Not that easy to change anymore from what I understand. Is this a new BBS02 or older? (CAN vs. UART) I'm not sure when the change was made?
You may want to review the way the Bafang UART drives can be programmed -
This is the BBS02 UART and I have the programming cable. I’ve already changed a few settings.
The UART .el file is just a text file. You can save and view them. Here's what mine looks like -
LBP=41
LC=25
ALC0=1
ALC1=36
ALC2=36
ALC3=56
ALC4=56
ALC5=66
ALC6=66
ALC7=80
ALC8=80
ALC9=100
ALBP0=1
ALBP1=36
ALBP2=36
ALBP3=38
ALBP4=38
ALBP5=40
ALBP6=40
ALBP7=50
ALBP8=50
ALBP9=100
WD=11
SMM=0
SMS=1
[Pedal Assist]
PT=2
DA=0
SL=0
SSM=4
WM=0
SC=10
SDN=4
TS=25
CD=7
SD=0
KC=60
[Throttle Handle]
SV=11
EV=42
MODE=1
DA=10
SL=26
SC=10
You can even trade the files. I'll attach mine.
  • bbhsd3a.el.txt
I have the old UART BBS02 and it's as smooth as silk with the 48V batt. Funny how yours is over powered in PAS-1. Did you start from factory settings in the controller? Perhaps a reset to factory if not, and see how that goes. PAS-1 wouldn't pull the skin of a rice pudding @ 48V, I rarely use it.
