I have a BBS02 conversion with a 48V battery and 500C display. The voltage indicated on the display recently starting reading about 5 volts lower than actual. It appears to be controller related as different displays show the same voltage and I have confirmed that the reading is about 5 volts lower than the battery voltage. I really don't care as I use my own power meter and shunt BUT have an issue with the cut-off voltage which would occur at 46V rather than the former 41V greatly reducing range. I have reduced the cutoff to the minimum (38V) but it is still reducing available battery some. Any idea what is going on?
