jonsully
1 W
Has anybody thought about or attempted to change the internal step-down gearing of a BBSHD? I'm not sure if it's even possible, but it's something I'm curious about. I know the BBSHD has a final step-down (total ratio of both steps?) of 21.9:1, and that yields a top output shaft speed of around 150rpm, I think? Most people reference the full speed of the motor around 150-170rpm (WAY beyond human cadence), though of course this varies with voltage.
Essentially I'm curious if it's possible to modify the internals of the BBSHD so that at 'full' / top electric motor speed the output shaft RPM is actually halved from OEM. E.g. instead of 150-170, 75-85 rpm.
Would that require fabricating a new set of gears to fit in the same physical space but have a different number of teeth or something? Has anybody considered doing this? I love the BBSHD through and through but would love it if its maximum efficiency point was at human cadence levels (plus it would mean high-torque moments are even softer on the nylon gearing)
