anon0973923
So I finally got everything put together (Aotema kit, 4x6s 35C HK lipo), took my ebike for a ride around the neighborhood ( ) and everything worked great. Came back to charge the batteries and the 5.5mm bullets on one of my lipo packs shorted, shattering the bullets
Still have no clue how it happened considering the + bullet is completely shrouded in plastic. Sweat, possibly. Or maybe the high-C batteries are too powerful for this type of connector due to arcing? Regardless, I had to finally cave and drive to home depot to get a soldering kit, shrink wrap, etc since I had to make it into work today on the bike. I had enough extra deans plugs and 5.5mm to deans adapters around that I could barely scrape by, by charging my packs individually and then using a terminal deans connector for the serial connection to the controller. I made it to work, so yay. Also, the battery that shorted balanced perfectly on my charger without any errors so it looks like I didn't do too much damage.
BUT, soldering the deans connection was possibly the most frustrating thing I have done in several years. The 35C lipos have 8AWG wire so trying to solder them solidly to the tiny deans plug was crazy-hard, I actually had to stay up until 2am just to solder the single terminal plug. And those big wires conduct so much heat it was nearly impossible to keep my shrink wrap from pre-shrinking. It turned out well, but dammit if I didn't want to stick the iron in my eye a few times. The wire was so thick it was too difficult to get the solder to flow properly unless I had the tip directly on the solder. It flowed perfectly fine on the deans terminal so I think the thickness of the wire was really working against me.
So now I've got all of these lipos with 5.5mm bullets that I'm ghastly afraid of. I'd love to swap them out for something different, but there's no way I'm going through that saga of soldering the deans connectors onto all of them. No way. I should also mention that I currently have some custom serial and parallel wireless deans plugs that I use in lieu of a wiring harness so I can connect my batteries in a foolproof manner to the charger and my controller. What I want to do is permanently parallel my two pairs of 6s and then use a similar custom plug setup using my new connector du jour. One of my main requirements is that the battery pack is easy to connect and disconnect from the controller (my controller is permanently mounted and I take my batteries in side with me at work) with a connection that I don't need to worry about being too rough with since I have to disconnect my batteries 3-4 times a day. I'm also concerned that once I parallel the 8AWG wires from the batteries, it's going to need a serious connector in order to accommodate all of that wire.
Suggestions?
Suggestions?
