Chalo
100 TW
I would like to know if anybody has trued or machined a motor shaft without extracting it from the motor. I'm looking for tips or observations before I attempt it myself.
Here's the background: Some years ago, I bought a Transmagnetics double stack 800W motor and controller from Thunderstruck EV. The motor is furnished with a plain 16mm (.630") shaft that protrudes about an inch and a half from the motor's face. I don't know what's the matter with mine, but it has visible runout-- enough to make me worry about cyclic tension problems for a belt or chain. It appears to be bent, because there is no discernible runout at the shaft root.
I would like to use the motor as a self-lathe and reduce the shaft diameter until it runs true. It's not clear to me whether I can clean it up by going down to 5/8" diameter, which would only remove .005" from the shaft. I think the runout probably would not be cleaned up by a .005" diametral cut, though I haven't put a dial indicator on it to find out for sure. My working assumption has been that I would reduce the shaft diameter to 15mm and maybe cut a Woodruff key seat.
Has anyone successfully turned down a shaft to a smaller size by running the motor against a grinding or cutting tool? If so, how did you do it and how did it come out?
