nutnspecial
🏍️ Giga poster
Greetings 2025
I was lucky enough to get some BHT motors back in the day, to make my single reduction mid drive. It is still running strong and I'd love to see how it does against the new CYC gen4 with a cassette and also the single reductions.
I'm aware most if not all middrives including surons use lighter higher kV motors needing 2 reductions.
Not interested in that. Less noise and better durability/reliability with a 'slower' motor. Like I think zero's are pob single reduced, and maybe some of the e dirtbikes too. . . .
Am accumulating parts to build another improved and possibly higher power of the same mantra design, but am having ZERO luck finding anything equivalent to these old BHT with rpm's/volt.
Looking for bldc's weighing at or close to ~15lb max with about 20 to 25 rpm per volt.
BHT weighs 11.2lb and spins ~2500rpm @ 100v. It works excellent for this ~72lb bike and lighter rider when geared for 40mph max. Throw 60-80a thru the controller and it's a great balance with alot of wattage in a small package, decent enough for prolonged low end grunt and what I consider a max reasonable topspeed.
I've tried many search terms and the problem lies with all the basic motor suppliers giving pretty generic spec ranges of volts and rpms, tho it's pretty obvious they are at least double the kV I'm looking for.
/////EDIT////// adding datasheet from Drum from bigblock alt motors thread linked below. Rather than my kV guesswork here is the data in blackwhite
