After being down for a few weeks due to ultimately
destroying my controller
I am trying hydros, more suspension front and rear, more normal stem, new controller placement and wiring technique, and fresh tires.
100 to 120mm fork
165 to 195mm shock
bb5 to 180/160 hydros
about 4-1/2" to 2-1/2 stem
initial impression is feeling a little cramped when seated in cockpit/ diminished pedal stroke with seat where I can still put my feet down. For the type of riding I like @ this power level, I think it will be better suited tho overall. Also me and the light frame will no doubt like more suspension.
When I had changed to down to the 165mm, I liked the look of the bike, but the bb went down to more like a normal height. Pedal strikes and bb clearance sucked, and the ride felt alot rougher. I ride the larger travel with alot of sag, so it still rides low enough but has alot of travel drop for my prefered riding type.
First impressions of the hydros? If these things hold up, 100$ is worth it on any and every bike.
You just bolt them up- no messing with stretchy cables and constantly fiddling with pad adjustment.
They feel AWESOME, can't wait to ride.
_____________________________
Dam it though, I wish I'd bought some 5.8ah turnigys (or zippys) earlier for 60-65$ pc to elimate these weak 4s packs and take the bike back to 18s. I can't even find them now!
http://www.hobbyking.com/hobbyking/store/__26712__ZIPPY_Flightmax_5800mAh_6S1P_30C_UK_Warehouse_.html
Ah, Uk has zippy for 52/pc. [strike]Might try ordering from there.[/strike] But can't order from there!
Also working on swapping CA (monitor only) for at least a voltmeter, and hopefully an ammeter too, without another shunt.
I would also love to roll back amperage on the fly to sometimes utilize some weaker 16ah multistars and/or just extend range. An external pot to mod controller's shunt reading sounds dangerous though.
