A 100 Ohm, 1W, carbon resistor in the end of a 5.5mm bullet.
Drilled 3.5mm hole in end of a 5.5mm bullet, down to about 2/3rd resistor length, held bullet together for drilling by cutting down a 5.5mm socket into a ring, to go around the bullet.
The carbon resistor doesn't appear to be fragile, after removing its coating, it's got a spiral pattern on it, I think that's the actual resistor and the body is a substrate.
Detached one resistor end cap and filed off outer coating left about 1/3 covered and exposed other end cap by filing.
Placed a tiny insert of TRS rubber against the resistor side, when pushed into bullet end, to hold it in place, it must be some kind of compressible material otherwise when the bullet is pulled out, the resistor will fall out the end and when connecting, if the insert is too hard, the bullet end won't compress for insertion into the socket.
The resistance value changed a bit, to 133 Ohms when measured.
Did the same with a 1000 Ohm, 5W, had to drill a 4mm hole this time and put a tiny bead of silicone close to the exposed tip, for both insulating and holding resistor in place and have left the ring around the bullet till the silicon dries.
Things to bear in mind, be careful when drilling to drill straight down, the bullet seemed to guide it naturally.
The bullet is now thinner walled, due to drilling, it doesn't appear to affect the inserting or the bullets stiffness as the resistor is inside it, but it should affect the current rating of the bullet a bit, because it's volume has decreased, but most of the current should flow through the gold plated layer and my setup is only 20A max.
How will affect the resistor power rating, not to sure, if anything the brass inner bullet should provide some heat sinking for the resistor, possibly increasing it's power rating.
