NightriderCZ
Hello everyone!
My first post here, I hope it's not too stupid
We have an e-bike (trike) with a BionX system: 48 V battery, G2 control console and direct hub motor with 350 W nominal power. The rider has neuropathic legs and fingers, so the e-assist must:
- be able to take off from standstill,
- provide very sensitive response to weak pedaling force,
- be strong enough to pull up hills, offroad etc.,
- be able to run at normal bicycle speeds on level ground (25 km/h is fine),
- not rely on correct gear shifting.
The BionX has met these requirements pretty well, until the motor developed a strange glitch: when it pulls at high torque, it periodically stutters. There's a knocking sound as if it was hit by a little hammer and driving torque decreases for an instant, then returns to normal. It feels like ABS in a car, but limits the drive instead of braking. We suspected it might have been caused by ruining the rotor magnets by overheating them, but now we bought a brand new motor (actually brand old, from 2013, but never used) and it does the same thing from the very beginning, without even warming up.
Our technician says he has seen several motors do this, and has never been able to either cure a stuttering motor, or make a good motor begin to stutter. He suspects saturation of magnets or coils and overcurrent protection kicking in, but that's just a wild guess - no way to measure anything because control unit is sealed inside the motor. And no way to debug the firmware, all he can do is to modify configuration parametres.
Is there any solution to this problem, other than limiting the power to lower levels where it doesn't occur?
