I can't take risks on a customer bike or else we will end up with a broken down bike in the bush! I found a vancouver dealer who sent me 1 quart!dnmun said:you could have left the magnets in place and used some bearing retainer to bond them in place. it is thin like super glue and just as strong. it wicks into the tightest cracks and you coulda helped by peeling them up a little to insure full coverage on the back of the magnets.
dnmun said:609 is what i have used, but you are assuming that the magnets delaminated because of heat.
is that truly the case or was it just failure of the original and inadequate bonding?
Lol no wonder. Its all good dude!dnmun said:i did not realizer this is an ICE engine. i thought we were talking about a geared hub motor. sorry.
Arlo1 said:Lol no wonder. Its all good dude!dnmun said:i did not realizer this is an ICE engine. i thought we were talking about a geared hub motor. sorry.
Now i have a quart of awesome epoxy for making custom electric motors!!!
I had that problem once the dentist wanted 800-900 to fix a crumbling tooth and I asked if there was a cheeper option he said he could pull it for 50 bux!Gordo said:Arlo; Can you epoxy a tooth together. Dentist wants $1300 to finish off after already spending $1100 for root canals on it. Two good ebike's worth of $$$ for a built in food processor! Maybe I just buy a blender and a straw?
I will have to look up the recipt at my shop next time Im there. I just googled lockite canada and got linked to one phone number then called them and they give me another one and called there and they give me another one lol.whatever said:3m 2216 ( grey) is a glue used in aircraft someone might want to compare specs for use with mags
arlo1 can you share your vancouver source for your glue?
Hey bigmoose I cant find to much about curing other then a little more then room temp will help and it can be fully curred at 150 deg F in a hour. I am about to use this for making the outrunner for my girfriends scooter!bigmoose said:Thanks Arlo1! Notice the accelerate heat cure that is cited in the article. 24 hours at room temperature then elevated as specified. The use in the engine oil will finish the cure. It is pretty good at 24 hours, but gets better. Here is hoping it continues well for you. It is amazing how much it thins with the hardener. Another magic feature of chemistry.
