Hey all, my chargers acting up.
I was following the OP's posts in the beginning about the charger that would not start spinning its fan, like my charger currently, but that story didn't seem to have a conclusion. Sorry have only read the first couple pages of the thread.
The charger is a 60.5V 5A charger I got from ping. The battery I'm charging is 14s 4p battery with 18650 samsung Li-NCM cells and 40A BMS all put together by cell-man. I've lowered output voltage to 58.8V for the battery, as it needs 4.2V per cell. See pics at bottom, I dunno why its not showing the whole width of the pics.
Here are some symptoms and tests I've done:
- I plug the charger into the battery and voltage drops to the battery voltage(52V) and the charge current is only 0.25A. The charger fan does not turn on automatically.
- I have tested the charger on a resistor and the fan in the charger was turning on and it was putting out 44V and 3.5A.
- when battery voltage was at 46V the charge current was about 2.5A initially and the charger fan turned on. The charge current decreased quickly as battery voltage increased and at about 48.5V the charger fan turned off, I'm guessing charge current was about 0.4A based on the next test.
- with the charge voltage set at 59.5V and battery resting voltage 49.3V, it charges at 0.33A.
- Currently the output voltage will not adjust higher than 59.5V. Although the charger was originally 60.5V.
- The battery has reached 57.7V after 2-3 days charging and charge current is 0. When I connect the charger I measure the charger voltage 58.7V and 0A. There is no charge current even if I raise the charge voltage to 59.7V.
- After that I connected the charger to the discharge leads it charges at 58.1V and 0.05A. With the charger off, battery voltage was 57.7V.
Things I have done that could be suspect:
- I did adjust the output voltage with the charger on.
- there was a big spark when I first connected it to the battery with the charger off. It blinded me for a bit because it was dark...
- I transported the charger in checked luggage on a couple flights.
Ping and cell man have told me its dead... I hope it just needs some of dnmun's prayers
what do you you all think?
1
2
3
4
5
