Cyclomania
Hmm. Any idea how the wiring should be soldered on here?Looks like 14s6p = 84 cells. 14s7p would have been 98 cells, so doesn't fit in that case.
The reason you have two rows of 6 next to each other most of those plates is because you are suppose to put six cells' positive ends down on one half of the plate, then 6 cells negative ends down on the other half - creating the series connection between two p-groups. You'll notice the end of the battery has a plate with only 6 instead of 12 spots. That's because that's for the last p-group which only needs one serial connection, which is done by the 12 spots plate on the other half of the battery. So that half of the battery only needs a 6-spot plate facing the 12 spot one.
I get a bit confused when everything is diagonal for some reason
Anyhow I think the pattern is correct now, as I've laid it down on the table here below to the right. Just trying to figure out where I should solder on my cables going to the bms now, so I am not doing it wrong
A bit confused since everyhing is diagonal and so on
