Bms refitting info..
alan6770
100 µW
Hi members can anyone give me info and guidance please.lol.
I know that the 3 small red positive wires solder to the battery positive , and the 3 negative wires to the opposite side negative cells ,
But can anyone, help me out please with the process and order in the bms wires..I've labelled ..thanks
Usually bms allow for some sort balanced charging, which means they try to avoid the explosion of one series group while the others are barely charged. Do do that, the board needs to be connected to each cells groups, as shown on this simple pic of 3 cells in series. On a sidenote: it's usually no a good idea to use different cells in the same pack. Each one has its one internal resistance, so usually the one with the lowest resistance wear off quicker.
