dnmun
1 PW
still don't know what flat lining is or how you measured the voltages. but if this is lipo like you said then you should not be using the ping signalab since it is made for lifepo4 cells. but i am assuming it is lifepo4 if this is a vpower pack.
is there any way you could show how and where you are measuring and what the actual voltages are when it is off the charger and what they are on the charger?
why did you expect a voltage on P-? do you realize that the BMS is connected at the bottom of the pack and it should be zero on B-?
you may have had no problem with the other BMSs you have replaced.
