BMS wiring seems a bit tricky
ebike11
far away
Hi guys
Im hoping to get some help for wiring my first diy bms to my LG pouch cells.
I have 18 cells of long LG pouch type like this..but not these exact ones. However the dimensions are the same.
https://m.dhgate.com/product/ev-battery-high-capacity-3-6v-60ah-prismatic/472469652.html#redirect_detail=PC2WAP
Because of their length, I had to mount them separately in different areas of the bike (inside the frame and on the rear rack)
I can not physically connected all 18cells together as it wont fit my application, so splitting the cells up is my only option.
The 2 packs in the center of the photo below were able to be connected with short wiring and those 10 cells are in the same bag.
Also since I wasnt using a bms, i just connected separate JST plugs for each pack to monitor the cells
Since each pack has its own main positive and negative connector, i had to make 3 way connectors to connect packs to each other to increase the voltage.
Ive recently purchased a bms so Id like to wire it up.
Since I have 4 JST plugs already connected, could I just run the bms balance JST wires to those? If its possible then i need to wire them in the correct order correct? Id have to be careful.
I have the main wiring from the bms wired up..just need to focus on the balance wires.
Any tips will be greatly appreciated! Thanks!!
Looking at your picture (as the link doesn't work)
Neg of the 3 cell pack is your 1st wire on the bms followed by your 3 pos wires on the same jst.
Next are the 5 pos wires on the jst to the left (Skip the Neg)
Again next are the 5 pos wires on the jst to the left (Skip the Neg)
You can then test this with a volt meter from your original Jst neg to each of the pos wires and the volts will increase by 1 cell per each wire.
You can always test this before you connect the bms
Jonne
Jonne
Thanks for your reply!
I have fixed the link above
I will follow your instructions..its my first time wiring a bms
Jonne
Hi..dont you have to make a Y-split when connecting different packs, from the last cell to the first cell of the other pack?
If you think about it your 4 large packs are just 1 big pack in series, they just have a pos/neg wire separating each pack. Therefor you you want the neg of the bms on the neg of the neg of the 1st cell on the series neg end (the 3 cell jst neg) then 1,2,3 then 1,2,3,4,5 from the pack to the left and so on.
Your bms will not work unless all 4 packs are connect in series.
I can draw it up if you are still confused : :)
Jonno
