skyungjae
Man... that's just terrible.
You have had constant problems over at least a year with BMSB but you keep ordering from them and complaining about what you get, I can't help but think you are at least a little bit taking advantage of the system.friendly1uk said:Paypal ruled I must send it all back
I said I can't it's dangerous goods
They said, return what I can.
No cases open. $386 in credit. The cost of the battery.
So there it is. I got my refund and the below par battery. Only just though. So... who else sells these 09 boxes and bms boards. I need a new supplier. Mine hates me lol
gridlok said:They also shipped me some stupid big car-jumpstart kit or something like that along with the battery. It didn't have instructions and I have no idea what it is for. I didn't order it and it weighed 3 lbs and was the size of a good sized hardcover book.
Why would they ship me this cheap heavy crap I didn't even order and add even more money to the already astronomical shipping costs. I just don't get it. Do they think I'm going to try to jumpstart my 12V lead acid battery with a $500 LithIon 48v battery? Never had problems with Paul.
Karl
d8veh said:In my last order from BMSB, I had a defective charger. It blew its fuse as soon as I plugged it into the wall. I sent an email to them asking whether I could get a replacement. The next day, I got a reply with a tracking number. 5 days later (today) I have my replacement charger.
When you burn out a motor, I would be very suspicious about whether it had been abused, so I can understand a seller being reluctant to do anything. Some sellers add extra to their prices to allow for that, so they can give replacements regardless of what happened. BMSB are selling at more or less bottom prices, so you don't pay for or get any insurance against your mistreatment of their stuff. If you got a DOA battery or charger, it would be different because their failure through abuse would be much less likely.
Motors don't burn for no reason. The same with a controller. If someone buys a kit, it's up to them to choose the right stuff for their needs. If someone bought a 328 rpm Q100 and a 15A controller and held full throttle up a 10% hill, I would expect something to burn. This stuff isn't fail-safe wherever you get it from.
Shipping is often expensive from China. It doesn't matter a hoot how much it is. You add the cost of the shipping to your order and then look at the total cost. BMSB normally comes lower than others, but what's more important is that they have some very nice stuff, like the S12S controller, that I haven't found anywhere else. They always seem to get the nice stuff before anybody else too. They now do the downtube batteries with integrated 20A controllers and torque sensors, plus the new PAS sensors that clip in the BB on the left side. That's the main reason I continue to use them. I'm now up to 29 orders as a hobbyist and soon to place my 30th.
I hope this post gives some understanding and confidence to people that want to use BMSB. I have no connection with them as I am English and based in UK. Many members on the UK electric bike use them without any problems. Here, you won't find anything against them. It's only on ES that I've seen problems reported.
Thanks for that. I'll have a look at it when I have a bit more time. I opened the case. They have little retaining plates that hold the transistors against the side. The plates hold two transistors and have a single screw in the middle. They look very close to the legs, which are staggered fore and aft. I didn't want to fully disassemble because I thought I might have to send it back. I'll probably be back for a bit more help when I get around to it.dnmun said:d8veh said:In my last order from BMSB, I had a defective charger. It blew its fuse as soon as I plugged it into the wall. I sent an email to them asking whether I could get a replacement. The next day, I got a reply with a tracking number. 5 days later (today) I have my replacement charger.
if the charger blew the fuse on first plug in then it is likely to be shorted between the collector/tab of the switching transistor and the case
you can look to see if the rubber insulating pad underneath the back of the transistor is out of position or it may be shorted through the silicone rubber by a piece of metal, which has happened on one of the chargers i repaired.
easy to check by using the DVM and checking continuity between the tab on the transistors and the case.
