Charged all the cells up to ~3.4V & rode around 27 miles. Still 57V in the battery (3.17V/cell) so riding to work and back would appear to be quite feasible.
Excellent! Cells all seem nicely balanced so can bulk charge for now
Charging with the 48V "meanwell" followed by boost converter (total £27 of ebays finest ...). Next charge will be solar ( + boost converter).
Bought some connectors for the bms and the usb/rs232 thing has arrived. I now need yards & yards of wire for the balancing connections & decide where to fit it.
Oh yeah, clamp plates (stainless steel) were picked up today from the laser cutters to properly mount the batteries - another £20. I'll post a picture when they're all installed + I'll need some lengths of M6 studding too
OK - I can't see any other threads concerning using a cheap switcher + a boost converter in combination. This works pretty good,
I'm never confident that a cheap ebay switcher will current limit reliably or accurately. So the boost converter gives me 1) as many volts as I want (this £13 one goes over 100V) and 2) a reliable adjustable current limit. The switcher delivers 48V at up to 5A so I set the boost converter to 61.5V and 3A. This tops up the batteries nicely to around the 90% charge and limits the power draw from the switcher to 185W (+ about 10 for inefficiency) which the switcher can supply comfortably. In the final system the charging will be switched off by the BMS at 3.5V on the "fullest" cell so the boost voltage setpoint will be turned up a little as it now becomes a "safety backstop limit" for the event of charger controller failure. The 185W max is just 15A when I run the system off the solar battery bank, and this is comfortably below the 20A input current max for the boost converter. The system looks safe and effective. 3A charge current is 13hrs (to 40Ah) but I suspect it won't generally require the full 40Ah of juice to top it up!
The other advantage to the system of course is that no modification at all is required to any of the component parts. Nothing is dismantled or adjusted away from nominal settings or has extra components kludged on to make the circuit operate in a manner not intended by the designer.
