Wow, that's seriously impressive. One of my big fears regarding my RadWagon was the possibility of a damaged axle. Your trike is beyond amazing, thank you for showing me!
sure. i build stuff out of whatever i have, or can get cheap, as i don'treally have a budget for anything. :lol: so i've broken lots of stuff, and learned what not to do, the hard way.
i'm not an engineer, just a hack, so what i know about things is from my experience or that of others or both, along with whatever principles i've managed to stuff into my head along with all the other crap that doesn't belong in there.
I'm glad I'm not the only one who gets very alarmed by lots of creaking sounds from a wheel whose spokes are, ostensibly, properly tensioned.
especially for a front wheel, cuz a collapsed rear you jsut drag along and skid, but a front....
I guess I assumed, being a cargo bike and with these thicker spokes advertised at the time, that the manufacturer would've been selecting a better rim. I think that's probably not the case, however.
maybe, maybe not; my bet is always that whoever designs something makes a choice that is probably appropriate, but then the pennypinchers go in there and "well, we can get *this* part cheaper, and it can't really matter *that* much, so...". (true in everything that gets made, anwyhere,)
you can certainly build a wheel with thicker spokes and a stronger rim for those that will then be more capable than a ligher weight one, but that's not usually what happens. almost always, whether it's a diy build or a corporate one, they only thicken the spokes, because they don't understand how a spoked wheel actually works in practice.
until i saw the failures, i used to think the same way, cuz it's an easy mistake to make and without knowing what's going on in a wheel it's counterintuitive to use thinner spokes, thinking that the spokes 'hold up" the wheel like columns in a building, or "mag wheel" "spokes", or old wooden wheel types, etc., but they don't....
btw, if a wheel keeps realy going out of true, so that it's obviuos even when not using rim brakes, tha'ts a pretty serious problem that means either the rim is bent / deformed, or some spokes ahve such high tension compared to others that it's deforming the rim as the others loosen up.
if you ever have an old bike wheel you do'nt care about, i highly recommend getting a spoke nipple tool and going to whatever wheelbuilding site / page / videos suit your learning style, and playing with the wheel to see how wheels work--you will eventually learn enough to "see" which specific wheel problem you have when different things happen to your wheels.
(this is how i learned, as i used to collect every bike that no one wanted and use their parts to build things from, and experiment and take apart and reassemble just to learn how without risking my ride)
Was that manufacturer Rad Power Bikes? Because that's the ebike I have.
no, it was an a2b probably a metro but i don't remember since i only got the wheels, not the bike. (these ultramotors are great motors for my purposes so i have tried to collect them whenever i could get hold of them; stromer also used to use them).
i've seen a few rads and worked on a couple for upgraidng their controller/dispaly systems, and not seen wheel problems with them but they were used lightly and infrequently.
The big takeaways I am getting from this are 1.) for my existing ebike, when it next comes out of true and I take it to the shop, I want to ask my LBS to rebuild the wheel with new spokes and a new rim, and make sure they know the previous spokes were too thick;
it won't really matter to them what the old parts were if the wheel is being rebuilt--if they are competent at all, they will use the right spokes for the rim they are using. (and they'll already know the spokes are too thick for that rim, assuming that it is not a tougher rim made for that gauge's tension). they should also discuss with you about the right rim for the usage (weight carried, terrain, etc), as it matters. you might need a heavy duty wheel and that might mean a strogner rim that does handle the thicker spokes.
chalo recommended this over here if you have one of the 22" rw's
There are some 22" BMX rims that are plenty wide for a 3.0" tire, and plenty strong enough for cargo bike use. Alienation Vandal is 37mm wide, which is typical of "XL" BMX rims these days.
it isn't uncommon for a freshly built wheel to need slight retensioning after a few dozen miles; some wheelbuilders will put it thru that before providing it to the customer so ti just stays good and the customer doesn't have to come back for that part, some just tell them to bring it back then or if it pings, etc.
(note that typical bicycle spokes are 15g. sometiesm 14g. non-walmart-level bikes are likely to use butted spokes that are thinner by at least one gauge size in the middle, and thicker at the elbow end (single butted) and sometimes at both ends (double butted). that lets them tension better with less stress on the rim, but be thicker where the stresses of interface with the wheel parts are higher. decent bicycle rims can even deal with 13g, at least if they're butted down to 14 in the middle, but pure 12g just takes too much tension for cheap rims and cheap is the name of the game with just about all typical ebike stuff out there. )
i didn't see in here yet: is this the hubmotor wheel or the regular wheel that's failing? or is this one of the dual=-hubmotror rads?
a regular wheel is easier to build right and work better when wrong for longer than the hubmotor wheels just because of the size of the hub itself, for a number of reasons, so if the probelm is in the regular wheel and not in the hubmotor wheel, might be time to upgrade to heavy duty bike parts (rim, etc).
wheels can be built for all sorts of usages, but one for oen usage may not work well in another. regular bike parts can even be found in pedicab wheels that have to carry thousands of pounds of passengers, so it's certaily possible to build wheels that work for you.
and 2.) that I need to increase my technical skills and knowledge. I feel like my project to build up a bike from just the frameset - with the goal of adding a ToSeven or CYC kit to it along the way - would be a good way to learn, but am I biting off too much at once?
as long as you are willing to learn bits and pieces as you need them, you can do anything you want that you can find the budget for. (see my wolfybot project thread for the immense amount of things i'm still learning to begin achieving *that* goal).
just make sure you can keep your regular ride operational while the new one is in progress.
originally i just rode bikes utnil they broke then got another at a thrift store or yard sale and rode it to death, etc. as i had no idea how to fix anything more than a flat tire or other simple obvious mechanical things. at some point i started learning how to fix things, ran across sheldonbrown's site and my real adventure began, and i started building custom bikes for my needs intead of just trailers to pull behind the bike. then i started taking those bikes id ridden to deaht and using them for parts to make my bikes from, and collectging more. this was before i needed a motor....that was a whole other adventure.
personally, i like the simplicity of hubmotors, because a direct drive hubmtoro can be silent and virtually maintenance free. a geared hubmtoor is minimal maintenance and can be pretty quiet but not silent. either one of these can be driven by "any" controller so you have a huge range of ways the system can work and interface with the user. easy to customize the system to your needs.
a middrive requires all the bike's drivetrain to work correclty, and reuqiers being used correctly to not destroy that drivetrain, and you ar e usually limited to howver the designers of the drive thought it should work, whatever sensors it has built in, etc, and locked to the capabilities and uiser interface that they thougth was good...none of which may apply to how you use a system.
and you are locked to the parts sources for the system, if there are any spare parts avialable at all.
so if you go for a middrve, you have to make sure it will actually fit on the frame, that it works with the drivetrain on that frame, or the one you want o use on it, that it does the things you want it to do in the way y9ou want them to work, that it has spare parts from non-original-manufacturers (cuz some like bafang change and discontinue things without noticeand not everything is compatible with other units that have the same model!).
etc.
Thank you very much for your advice and for listening to the specific 'symptoms' I have on Cookie Policy (the name I have for my RadWagon).
i guess next time you'll have to read the whole thing before you accept the cookie policy.
Thank you also for your detailed pictures and technical information of your amazing bike! And here I had thought that Cookie Policy was a car replacement, but your SB Cruiser is on another level. It's awesome to see what's possible here.
not everything i built has been a success--poke around for the delta tripper thread. :lol:
the raine trike for my brother might be a success but he never uses it so i don't really know. i think it oculd use some improviements in hte pedal drivetrain but he would never use those anyway (*tehy're only there for legality on his trike, on mine i use them to control the motor system and as a backup in case all the motors fail).
tehre are even "better" cargo trikes; trucktrike is one i'd like to borrow bits of engineering from; they're not aroudn anymore but you can still find good images.
and things like this could be inspiring; you could build something like it for a lot less than the six thousand ish they want for it.
Electric box cargo bike delivery trike truck 3 three wheels motorized tricycle Electric box cargo bike delivery trike truck 3 three wheels motorized
mobility4less.com
