Batteryrepair
🔋 Established
- Joined
- Oct 7, 2022
- Messages
- 63
I own a repair shop and a customer came in with the statement that his range is way less than others with a powerpack 500.
i check the tire pressure, wheel alignment, brakes etc. Nothing wrong.
When capacity testing the battery I only measure 420Wh, despite the battery barely being used. It's 4 years old, yes, but that should'nt have that much influence on the capacity.
So i decide to open the battery to check the balance of the cells and see the following:
This pack from 2019 has 30Q cells in it, meaning the capacity is only 12Ah instead of the stated 13.4Ah.
Nothing but dishonest practices.
You only get 420Wh from the start, might as well buy a powerpack 400 then and save yourself €200.
I know it's always a gamble which cells you get with the Bosch powerpacks, but atleast so far it was always cells of atleast 3.3Ah, like the LGMJ1, Samsung 35E or Sony VC7. If you had bad luck you get a Sanyo pack, but never a 12Ah instead of 13.4Ah.
The date on the BMS matches the pack, so i'm sure this is an original. Also the spotwelds and nickelstrip are 100% original.
