I've been going back and forth a lot on what I want to build. Some of this is a product of the Ebike learning curve and some due to the fact that I'm waiting for that quarterly bonus check from work to get here. Anyway, I think I finally have my vision sorted out and would like to hear what everyone thinks. Planned use is a relatively flat commute of 10 miles which might grow to up to 20 miles in the next year.
The plan:
I plan to start with one of these. This one has been converted to single speed, but they actually come as a seven-speed with the shifters mounted to the headtube. Steel frame and fork and 135mm in the back. Converting to a flat bar should be no problem.
For the motor I plan to go with Grin. I want to order the Clyte 3540 in a 20" wheel. I don't think that will be a big deal. I'm going to get the 40 amp controller and use 18S2P 8000mah lipo which should equate to about 12.8a/h usable. Plan is to mount the lipo in the frame, but I will probably start out with them in a box bolted to the seat stays above the rear wheel and the controller mounted inside the rear triangle. I plan on charging at home and work and will take the proper precautions so I don't burn anything down. I'm not going to charge to the full 4.2V and don't plan on discharging past the cliff.
What I like about this plan, if the simulations are correct, is that top speed should be in the 35mph range and the acceleration should be pretty perky. On the 10 mile commute range should be ok at WOT if I charge at work or if I throttle back to under 30mph, should be able to do the full route there and back. If my commute gets longer, I can dial the power back with the CA and will have to charge at work.
Comfort is not a huge concern for me and I know I'm giving some up on this build. I know I could probably do it cheaper, but I have gone the cheap route on so many other things before and this time I don't mind spending a bit more. I do see an issue that even with a 54 on the front, I will run out of gear around 27-30mph. I think I can live with that.
Did I miss anything?
The plan:
