Hello,
I bought a ASI855 from Martin but he's a very busy guy and I didn't get the BBSHD harness. It's surprising as I noticed that it was usually sold as part of the kit. So well... unless I find one somewhere which seems very hard. Electron Cycles in UK don't sell only the harness as an example.
In a nutshell this is what I need to build
So I'm going to try to build it myself and share with you this journey. I'm sure it's not ultra hard but I want to get it right and I'm missing some connectors.
I had a harness provided with the BBSHD, so I decided to cut at the end of the 8 PIN connector in order to use these pins.
so I'm here with 13 wires. I believe I'm going to wire them directly to the ASI connector but I'm wondering if I need to split some of them or just go 1 to 1...
I'm also looking for all the connectors that I have from the BBSHD controller so I can replicate the same connectivity with the BBSHD motor. I could cut them and use the BBSHD controller ones but in case I want to sell or use later on my BBSHD controller.. I prefer to buy new connectors. I will not need the 13 pin (will wire it directly to the ASI) neither the battery cables (will be using XT90).
Does anyone knows the reference of each connector that you see on the photos below?
We'll need that later but this is the BBSHD diagram
and this is the ASI diagram
Looking forward to your advices and I hope this topic will be useful to others !
