Vendetta277
- Joined
- Jul 19, 2014
- Messages
- 21
Hi fellas ,
after some time I'm now into the idea to build a 3phase brushless motor myself.
I already have 2 bearings that can hold an 18mm shaft. , a wooden baseplate and some material in general
i also own an arduino uC and got quiet some knowledge about electrotechnical engineering.
BUT i need some help with the ESC and motor design.
base idea : 6 powermosfet for 3 phases is ok ..i think.
the motor should be around 1-5kW , and is allowed to be 30cm x 30cm x 30cm
im ordering some 50V , 40A N-ch. Powermosfets with 0.1ohms fully opened.
they are switched on and of by my arduino or arduino+driver circuit.
the uC is also the part that deals with my hallsensor placed near or between the coils in order to deliver positioning information.
i will need some big Capacitors ,too , but no idea how big they have to be in order to buffer those large values of current effectively.
theres obviously a big heatsink ,too
important questions :
1.Current
I want to have a maximum load current of about 80amps. so the current drawn when i start driving my cart will be around 150 amps or something
-> what size does my wires have to be in order to NOT burn down all the way ? ( am i allowed to use multiple wires for 1 coil so i reach a bearable division of current )
2. Design
there are neodymium magnets in all shapes and prices. and there are many designs to put together a bldc motor.
what would be the most effective way to put together coils and magnets ?
big outrunner magnets (4) and 12 coils ........OR............ 6 coils and 2 inrunner magnets.... OR ......... 9 coils on 12 outrunner magnets? ... OR even magnets each side to the coils (before and behind )
i still dont know what would be the most effective way to operate and build with.
3.Timing
as far as i know , those magnetic fields need time in order to establish and fall down , so the switching times are going to be earlier and earlier the faster the motor goes.
am i right ? or are those magnetic fields fast enough in order to up and down 100s of times a second.
--> most outrunner motors are wound arround ferrous material with a ferrous dome facing to the magnets.
if my thoughts are right , these are here to increase the density of the magnetic field lines , so the poles are becoming stronger. -> arent those slowing down the process of the pulsing fields ?
PLS HELP
I know , a lot of questions , but where would u find a REAL expert with REAL practical experience in building blcd's so easily.
greetz!
1.Current
2. Design
3.Timing
PLS HELP
greetz!
