Hi Bull3T, please read back through my posts for information on all the capacitor and power-supply issues.
You will need 2.0 to 3.0F of genuine capacitance, as supplied by the recommended Scosche, Rockford or Monster capacitors.
Anything else, other than those 3 brands, or the genuine computer grade electrolytic capacitors, and you are wasting your time.
It is advisable to get a power supply with a monitor, so you can perform test welds and keep performance data notes and it also allows you to visually note the capacitors recharging.
Joining the capacitors, in parallel, negative to negative, positive to positive, with copper bus bars is highly recommended. I noticed a massive difference between 8ga 200Amp rated copper jump leads and quarter-inch thick, inch wide bus bars. The bus bars are king. Basically, with audio caps, even the very good ones, you need every ounce of capacitance you can get your mitts on, no point in spending money on good caps and then seeing all your precious amps get frittered away on poor connections and poor connectivity.
