The p/n on the one I have here (not yet built into a welder) is 034976 (0220 Italy), 175A 300V. It has an IR logo, but is a Miller welder part, so it may not be the IR p/n.
A search on similar body styles and ratings finds a 2N3887 by Powerex
http://html.alldatasheet.com/html-pdf/20551/POWEREX/2N3887/245/1/2N3887.html
but I think it's physically smaller than the one I have. IR doesn't seem to make SCRs anymore? Or I am totally missing them on their site.
The Powerex site shows a list of some high-current SCRs, but they only go up to maybe 5000A or so:
http://www.pwrx.com/Grids.aspx?g=140&m=25
a 600V 5000A version is only a bit over 14cm across and almost 3cm thick.
Everywhere I can actually find them for sale, there is no price, only an RFQ link, so they are probably so expensive individually you couldn't afford one, even if they would sell you just one.
I did about 10 minutes of googling for various SCRs, and looking at various manufacturers of them, and under 100A is fairly common. After that they get rare, and over 1000A there is almost nothing. I found zero over 5000A. I'm sure there are some, but you'd have to know where to look, apparently (and I'm usually fairly good at searching for things).
The one I have is larger diameter than a quarter for the body, wieghs a pound or two, with a threaded bolt-end that's larger than any of my hubmotor axles or the NuVinci axle. :lol: Almost as large a threaded section diameter as my Fusin's axle nut. Nto sure what gauge wire it has pre-mounted on the end, but it is as large as my pinky finger.
I haven't built my welder yet, but based on size and the prices found in a quick google search ($150-$300 and up) for just the low-end one I have, it would probably be a lot cheaper to use lots of paralleled FETs to do the job. If I didn't already have this one, that's probably what I would do, and if (when?) I blow this up, that's almost certainly what I *will* do. :lol:
