I need to design and build one to charge my 29s Lifepo4 pack.
In fact it must be a switched-mode power supply (inverter) with regulated 106V output voltage and around 10A limited current (but variable voltage and current is a nice to have). My cell balancer is in the BMS, so only one high voltage output is needed.
It should be small and light, portable (max. 1kg including box...?) and high efficiency (without a fan if possible).
The mains input is 230VAC. The output must be isolated, but I don't have experience in designing with HF power transformers yet.
Has someone already made a similar charger? Maybe schematics of a similar inverter, or any idea where to start? (operating frequency, transformer sizing, control circuit, etc.)
Thanks,
Peter
Thanks,
Peter
