Drove another 11 (18 total) miles without charging, down to 64% Blew the 30a fuse 2x properly in the middle on tough hills, I set the controller to 15a,(p14 on the controller) and it seems to make no difference, still getting 900+ watts (36V) with full throttle.
Is this that customer-return kit? Maybe the problem is that the display isn't sending data to the controller or controller isn't receiving it. In that case, no changes you make to the settings will be saved to the controller, so it will just run at whatever it's power up defaults are. Does it change behavior in any way, based on assist level changes? If not, this is a likely problem. Some systems give a comm error (E30, etc) in this event, but some only do that when the display can't read the controller, not when the controller can't read the display.
It can also be that the display has the wrong firmware for the controller it's paired with, so that it's data is the wrong format or the wrong values, so the controller ignores it. That's less likely since the display is providing you with the watts (which has to be calculated by the controller, or is based on amps that has to be calculated by controller).
Controller still says 100% battery, I think it is set for Li-on batteries, instead of Li-fe , I don't think that can be changed.
I have a Lishui-based system with Kingmeter display, IIRC, that always reads as if it was LiFePO4, and all the Lion batteries read full even when they're not until they're much less than full because it expects a lower voltage total.
If yours reads full even at only 64% for a 12s LiFePO4 battery, it's probably not using the right battery voltage range or is set for the wrong battery voltage entirely. Your battery should be at about 3.2v x 12x = 38.4v. Is that the voltage you see at this point?
A LiIon battery at that SoC is probably around 3.8 per cell, at 10s, so around 38v, so even if your display's meter was set to LiIon it should still show about right for your battery.
If your display is set to 24v battery, then it would show yours as full all the time, even when completely empty.
Fuse holder and fuse is not really hot, but the 30a Chinese fuses may be the issue. I dunno...
If the fuse holder or fuse are increased temperature under normal operation, something is wrong--either the parts are defective, or insufficiently capable for the current flowing thru them.
Also, keep in mind that fuses are "precision" parts, in that the fuse wire itself must be exactly the right metal composition and the right thickness / length / etc in order to correctly blow for a specific current rating.
If you look at the spec sheets for fuses such as those at Eaton / Bussman / etc, you'll find a chart in them that shows you how long a fuse takes to blow at a specific current. That is so that a fuse can be properly specified for a system, so that it will blow before wire / etc damage occurs, but will *never* fail under normal usage. It takes a certain amount of time
To pick the right fuse you need to know how much current you will have in that normal usage, *and* how much current will damage your wiring that the fuse is protecting (all the wire beyond the fuse point, which is typically right up at the cell block inside the battery, so that any short circuit that could cause a wiring fire instead blows the fuse without damaging any wiring). It
So the smallest wire in the battery + or - wires (the current path) is the weakest point, and whatever current it is meant to handle is the limit to pick the fuse for--the fuse should always be picked to blow before that current is reached.
But the fuse should be picked to never blow when normal usage current is reached and sustained, "forever".
If the fuse keeps blowing, then one of these is typically the problem, in the order they usually are seen in:
--a wiring fault exists (intermittent short, damaged insulation, etc)
--fuse is sized too small for the load it must handle
--fuseholder is not holding the fuse right and causing so much heat it melts the fuse; this always causes wiring insulation damage and usually causes melting of plastic parts nearby.
--fuse is defective or poorly manufactured
