Would anyone really, honestly put that heat job into the cooked motor category and allow Boy Scout into the Cooked Motor Club?
- Windings look fine, take the phase wires off and resolder new phase wires on, you will need a 60w iron to dump enough heat into the windings. Also remember to slip on some heavy duty heat shrink before you button it up, I almost forgot slipping heat shrink onto my battery wires doing the connector tonight, luckily I remembered this time. Also lucky I had bought some thicker heat shrink suitable for 10awg. I had an unexplained spark reconnecting my split battery after a charge a couple days ago, still dont know what happened. Had lots of light, in a bit of a hurry but not rushed. Luckily I had enough juice to get home, with a detour to the closest transit. I am using XT90's with a series adapter, a split male off the bullet wouldnt have done nothing bc it has its own separated housing. Maybe a hose clamp was biting into a cable, but I dont see no scrapes. Also lucky I can reuse some old XT90's and not use my good ones, I have a pile of XT60 but I prefer XT90 for my big fat fingers. I really do need to stock up on some cheap XT90's from Hobbyking, and some silicone wire in 12awg and 10awg.
